kaging
how to adjust fan speed?
kaging    0
not overclocked...yes its new.. i have one 120mm at the back of the case for exhaust.. and 4 infront 80mm.. one top of the case 80mm.. and one at the left side of the case 80mm...
knud    129
Did you attached it well, the heatsink?
And to make clear, was it a noise problem, or a heat problem where we talking off?
kaging    0
yes i did attached it well...no noise problem.. sorta heat problem bcuz i the fan speed is only 2066 rpm its kinda slow for my proc.. cuz my proc is very hot...just cant adjust the fan speed :((
nickster_uk    0
Hi kaging....have you managed to get your problem sorted yet?
I have bought a Vortex TX fan and i can't get mine to spin faster than 2089RPM's!
My MoBo supports PWM and it all looks to be set up correctly but no matter how hot my CPU gets, the fan refuses to spin any faster???
