kaging 0 Posted April 12, 2006 i just bought vortex tx.. and i cant change the fan speed..i have intel d915pgn as mobo...please help me my cpu is running 67C ( thanks in advance Share this post Link to post Share on other sites
knud 126 Posted April 12, 2006 I don't know if your mobo supports it, but perhaps it can control the fan speed. Otherwise use a fan controller (is the speed too low or too high / too loud?) Share this post Link to post Share on other sites
kaging 0 Posted April 12, 2006 is there any software for windows or linux to adjust the fan speed? i dont have any fan controller ( wats pwm? is it a software? Share this post Link to post Share on other sites
Infinity 0 Posted April 12, 2006 PWM is Pulse Width Modulation, try google for a full explanation Share this post Link to post Share on other sites
kaging 0 Posted April 12, 2006 yeah but.. cant fully understand.. sorry im still noob in hardwares..is still any other ways to adjust the fan speed?:/ Share this post Link to post Share on other sites
knud 126 Posted April 12, 2006 try using speedfan: speedfan That program is able to control your fanspeed, if the mobo supports it. Share this post Link to post Share on other sites
kaging 0 Posted April 12, 2006 thanks but how will i know if my mobo supports it?i checked the mobo info ddnt find any pwm :/ Share this post Link to post Share on other sites
knud 126 Posted April 12, 2006 Just instal it, and try to lower the fan speed using speedfan and see if it works. Share this post Link to post Share on other sites
kaging 0 Posted April 13, 2006 thanks but...i installed the speedfan.. and lower of higher the speed.. ddint work.. still running 2066-2069 is this its highest speed? i dont think so i read the specs it says it could reach 3200 rpm.. heheh my proc will burn soon :/ idling at 55-59C ...l i dont know :/ Share this post Link to post Share on other sites
knud 126 Posted April 13, 2006 It's a new cooler right? It's not overclocked I guess. Any fans for better airflow? Share this post Link to post Share on other sites
