Eskimo88
Heat problem in my new Wavemaster...
Eskimo88    0
Hi I am a proud owner of a new wavemaster chassi. But I have some heat problem. Just built my first computer and this is what i got
Pentium 4 3,2 ghz with zalman cpu cooler
Abit AI7 motherboard and antec tru 480 power.
If the side of the chassi is of i get a temp of 54C on the cpu when the side goes on trhe temp goes up to about 60C. If i open in the front for the 2 80mm fans i get 54C. Looks like the front fans wont get the air that they need to cool the chassi. What can i do need some help?!!( bigger front fans maby) or are these temps ok.
Mike.
Booradley    0
Those temps are about right from my experience. What are you using to read the temps? If you're using the ABIT EQ it does read temps a bit higher than they actually are.
If you you don't need the top mounted panal for USB, Firewire etc, take it out and put a fan up there, that will help with the air circulation a bit.
hope this helps
scooby    0
Hey Eskimo88,
I had the same issues with my WaveMaster so I recently cut a custom window on the panel and added a 92mm fan at 2200rpm/37cfm that sits right on top of my CPU's heatsink and fan.
Before the added fan;
Case temp: Idle 22-23c, Load 23-23.5c
CPU temps: Idle 36-37c, Load 39-40c
After adding the fan;
Case temp: Idle 18-19c, Load 20-21c
CPU temp: Idle 33.5-34.5c, Load 36-37c
I'm running an AMD system 200x11 @ 1.525v
Made a big difference for me and all that by just adding one fan in the right place.
Hope this helps :D
Guest Mindless Moron
ur system is hot cos u dont have any decent intakes, the wavemaster doesnt have very good frontal intakes. not enough airflow, and since the IO iso n the top theres no extractor gfan for hot air, i really think it could have been designed slightly better.
