brbsta
Help with CD4
brbsta    0
I just got my CD4 and wireed it all up. I didn't use any of the sencors because I already had all my comp together and didnt fell like taking it all apart again. All my fans are 4 pins. I used a 4 to 3 pin that came with the vantec fan and light controller that I also bought. These dont have the yellow wire for the rpm. So all the tiem the CD4 is on I have a flashing "OFF 0000". What is off? Also does anyone have 4 to 3 pin adapters that have the yellow wire so i can get the fan speed for the cpu. Then I have a vasntec tornado and it goes down alot but still seems that it dosnt go down enough way to loud. One more thing, is there any way to get a 2 to 3 pin adpater somewhere I have a ATI Silencer that i want to plug into the CD.
Thanks
