thebittersea
how to check liquid level and refill???? - AQUAGate
RaptorFury    0
ohh yea ... it would as long as you put the return line from rad to the top of res and put the res to pump at the bottom and try to keep the res somewhat close and higher then the pump/hs ...
it is possible to refill and or add liquid. HOWEVER, if you remove any of the tubes or the third unused tube, you will void the warranty. If you want to refill. do it 2 years after you bought it.
