dstao3489
Praetorian 730 - Will these parts fit?
dstao3489    0
So this is going to be my first time building a computer system and im really concerned if the parts i want will fit in the Praetorian 730.
Im planning to use
mobo: asus a8n32 deluxe
heatsink/fan: zalman CNPS9500
memory: Corsair TWINX2048-3500LLPRO
graphic card: eVGA GeForce 7800 GTX KO
psu: OCZ Powerstream sli 600w
so my biggest concern is if the fan will be to large for the case even if i take off the side duct. im also wondering if the fan will interfere will any other components such as the psu and the memory. the reason im concerned about the memory is because it's slightly taller than regular memory due to the built in heatsink. im also wondering if this video card would be too long for the case as well as if the case will have enough space for a second video card if i plan to get one in the future. so if anyone has an answer, i would greatly appreciate it.
I managed to fit a Hyper 6+ in mine :P - I am pretty sure that is bigger. Hard to tell tho really.
http://lib.store.yahoo.net/lib/xoxide/z ... -led-6.jpg
The fan does not seem to go higher than the PSU (which would of course bad)
you may need to remove the plastic from the sidepanel, but it works out quite well, check out
