Brok3n
Need some feedback.
I got my x-connect in today, it installed just fine in my wavemaster and all the rails are rock stable even under heavy use, better readings than my old antec true power believe it or not. You wouldn't believe how much space this PSU saves you. Also - all the cables connect just fine, no chance of them coming loose.
Some pictures of it in your system would be nice to see.
ajfaull    1
I just bought the Antec Neo 480, same idea, except the wires for the motherboard power and the four pin 12V motherboard connector are still wired conventionally. But all the drive connectors are removable and the cables lock into place. They even put two 4 pin molex and two SATA connectors that are user installable in the box so you can add more to the cables that come with it.
http://www.antec.com/us/productDetails.php?ProdID=24480
It's nice to see that this is starting to be done in manufacture. I've modded five power supplies this year and it's getting a little boring.
Arcey    0
Is the cable management system as use on the X-connect and
the Antec something we can hope to see on the CM Real Power ?
