titanx
Dual Storm Case Fan
Rating
20 members have voted
  1. 1. Rating
    • Excellent
      11
    • Very Good
      6
    • Good
      2
    • Fair
      0
    • Poor
      1
countzero    0
I'm not too sure on this one, I think the Hyper 6 looks a lot better.
This one looks a bit cheap and plasticky...not to my taste really.
I'd still be interested in seeing how it performs with the duel fans, sounds a bit like the compressors in a modern jet engine.
Hopefully you can run it at low RPMs and still achieve decent cooling.
Garfield    0
As I know, it's 8 cm Fan... and the SPAC as below:
Weight:192.67g
Fan Speed: Top1402rpm ~ 2986rpm, Down:1453rpm ~ 3056rpm)
Air Flow: 20CFM ~ 40CFM
Air Pressure: 1mmH2O ~ 4mmH2O
Noise: 22dB ~ 47.5dB
.....I think that will be ok for noise... 8)
Kahobi    0
This thing might make a good replacement for the fan on the Aquagate, just remove the old one and mount it on the exterior of the device....or something to mount on the exterior of the CM Stacker on the top vent...
Hybrid-Mods    0
I would use it primarly on a heatsink though, since the dual blade design is to create more pressure and a cyclone, to help kill the "dead spot" traditional fans leave.
As for using this with conjunction with the Hyper 6, that would just be interesting.
The true innovation in this product is outstanding, I could also go for one of these, without the 4 plastic things in front of the gold fan, but all we know.. they could be there to help pre-direct the air for the "cyclone" affect
