merovingian 0 Posted November 22, 2005 You probably need to run dividers for the ram.Follow these directions you have anything in noobish? that's too techie Nope, but this guide is really easy IMO. Hmm, is there something that isn't clear? Quote Share this post Link to post Share on other sites
RaptorFury 0 Posted November 22, 2005 firstly uneed ton o volts for 2.5 gighz the asus only allows 1.85 . is that a 3200 400 or a 3200 333 ? the desktop cpus can only reach 2.3 - 2.4 gighz at 1.85 volts in order to reach higher speeds u goin to need to do a volt mod on the board .... Quote Share this post Link to post Share on other sites
mw 0 Posted November 22, 2005 but i think i can go higher than 1.85volts ?!? What is safe - do you know? dont want to shock myself Quote Share this post Link to post Share on other sites
RaptorFury 0 Posted November 22, 2005 thats all thats allowed thru bios volt mods are hard mods that u do to the board i am currently at 2 volts on my cpu but my cpu never gets bove 38 idle 42 load ( gotta love tornados and winter ) Quote Share this post Link to post Share on other sites
mw 0 Posted November 22, 2005 ok then so how do you do a volt mod? is it worth doing and how complicated is it? next question , im at 1.75v at the mo - will it make any difference if i go to 1.85v multi at 12 , fsb 210 ??????? best overclock ideas Quote Share this post Link to post Share on other sites
ID 0 Posted November 22, 2005 Well considering you are a newb to overclocking, and that's not meant to be an insult, you should definitely stay away from volt-modding. You have to be pretty extreme to be doing that. Is there no way to unlock the multiplier on your mobo? Are you using the latest BIOS for that board? How fast is your RAM running at 2.31Ghz? Quote Share this post Link to post Share on other sites
merovingian 0 Posted November 22, 2005 I bet it's the HTT multi but I don't know what it's supposed to be normally, on my board it's 1000Mhz but I don't know if that appies to those chipsets Quote Share this post Link to post Share on other sites
ID 0 Posted November 23, 2005 I bet it's the HTT multi Yeah that's what I'm saying. Since the RAM divider is derived from the CPU multiplier, he's pretty much stuck if it's locked. And I'm betting it is... Quote Share this post Link to post Share on other sites
RaptorFury 0 Posted November 23, 2005 um that is a amd xp cpu most of those are multi locked unless he goes Mobile xp and xp's never supported htt they just straight leg cpu's , on his current set up what his mb will produce thats bout all it will muster up .If you had a mobile with decent cooling 2.5 wouldnt be hard at all ... but 2.5 isnt totally out of reach them nf2 chipsets are fairly easy to mod up if mem serves right theres a lil wire u stick in the cpu socket that will allow u more volts to the cpu but i highly recomend u research it and then get really good cooling like water bc them xp 3200 desktops get hot at round 1.85 volts ... Quote Share this post Link to post Share on other sites
mw 0 Posted November 23, 2005 ok im using geil ultra x 2x512meg if that helps ??? cpu is being cooled by a hyper6+ with low case temps all round! latest asus bios update. still only getting 2.31ghz................................ its stable ; but i want more god damn you !!!!!!!!!! its not worth the money to switch to a mobile processor really!?!? help help help Quote Share this post Link to post Share on other sites
