mw
XP3200 overclock help !!!
mw    0
Hi,
Having some difficulty overclocking an xp3200 with asus a7n8xe-deluxe mainboard :?:
I can set the multi to 12 and the fsb to 210 and leave the v.core at auto 1.75... :idea:
But all i can muster is 2.31ghz ??? How the :) do you guys get upto 2.5ghz???
P.S im using a 1gig of geil ultrax (yes i know-but it was cheap!) :?
The cooling is also good as im using your coolermaster hyper6+ inside a centurion 530
HELP ME , i need some advice - cheers in advance chaps :)
mw    0
I managed to read about half of that before i got bored! Is there not a reasonably easy solution to this problem?
I do have a life outside of piss arsing around with pc's
All i want is to make my pc fast and stable as possible without upgrading, and also so battlefield2 loads quicker!
Any other suggestions for overclocking xp3200
merovingian    0
210*12=2520Mhz
210*11=2310Mhz
So, you can't get a 12x multi, right?
mw    0
ok sorry to sound like a nOOb
what the :) is a memory setting ? and how do i change that ?
mainboard asus a7n8xe deluxe
sorry and thanks :shock:
merovingian    0
Don't have that board. Look for a DDR setting running at 200 in the bios, perhaps in the jumperfree config settings.
mw    0
nope , its no good - im def beat on this one! :evil:
I guess ill have to make do with 2.31 ghz - better than 2.2 :cry:
