DyNaRaX
CM Real Power 550 and HIC question
DyNaRaX    0
I have a Real Power 550W in my Stacker and I installed also the HID.
I noticed that the indicator on the HID is always around 100 W nomather what I'm doing (gaming, burn dvd,...)
Is this normal? I have the following stuff connected to the PSU:
Asus A7N8X Deluxe with AMD XP 2500+ and 2 DDR Sticks
1 Maxtor 120 Gb and one 10 Gb disk both ata
1 Lg DVDwriter
1 Creative Fx5900
1 floppy
1 iluminated fanbus
2 120 mm blue led case fan's
1 80 mm top fan
1 80 mm cpu fan
1 ccfl
1 usb joystick
1 keyboard and one optical mouse both on ps2
When using http://www.jscustompcs.com/power_supply/ I should be using around 277 (stressed)
ninuhadida    0
what is the range of what the display is showing ?
it doesn't mean you should get around 277w cuz it's impossible to have everything stressed out at the same time. i.e. - it doesn't mean while you're playing the dvd burner should be running/hdd fully stressed out.
ninuhadida    0
seems a bit strange, really. with that site you posted i get 331w a bit too low for my system IMO. maybe someone who has a RP can help you a bit better about your prob.
