tkrobson
aquagate 120 fit problem?
ninuhadida    0
hmm.. is your aquagate modded or left stock ? i'd remove the block, clean the cpu and block of any thermal paste, use artic silver 5 (put a size of a rice grain in the middle of the cpu) and re install the block on the mobo. can you feel any heat coming off at the back of teh aquagate ? or any noise from the fan in the aquagate ? now another thing you might wanna test.. when the bios is tellin ya that the temp is 60-75c touch the copper piece that is installed in the block and see if it's hot. if yes the bios is correct + making a contact with the cpu and if no either the bios is wrong or the block isn't making contact.
