orion23
Cooldrive 4 Help...
orion23    0
Hi,
I just bought a Cooldrive 4 and have a few questions for you guys.
With the Aerogate II, if the CPU fan connector is not being used, an alarm will sound everytime the PC is powered on.
Will this happen with the Cooldrive 4?
Can I just power the unit and not have to worry about using fan connectors or thermal sensors?
How does the cooldrive 4 compare to the newer cooldrive 6?
TIA!
RaptorFury    0
cool drive 4 uses the same stuff as the aero 2 try stickin the probe some place where it can be held on by the hdd then use a different type of tape to secure it . the ones supplied are good but they just not sticky enough ...
-_JonA_-    0
If you do not connect any cable there wouldn't be any noise I guess...
and there are no problems if you do not connect the thermal sensors to the Cooldrive4... only if you add the cable to a fanconnection, but when u don't add a fan on the cable thre will be a sound, by pressing the rotationbutting for a few seconds u can turn of or turn on the sound alarm... but when there is an alarm, the rotation button wil flash red colour....
