mwenke
Stacker: 2 fans and 5 Drives... possible?
mwenke    0
In the Stacker, is it possible to fit in 2 12cm fans and for drives at the top?
I am also considering waiting for the 830, will it be the same deal in that?
Thanks, mitch
**EDIT
A unrealted question, but no point posting 2 threads, will the 830 have bottom verterlation like the others?
Because i need a place to put my 2x 120mm Radiator, and i origonaly wanted to put it on the front, but after seeing the possition of the radiator in this: i guess i could just do that, but does the 830 have bottom venterlation?
mwenke    0
that isnt mine.. the pic was just from a review i was reading, and i got the idea of the radiator possition. Although, my current setup is a mess to, but i cant be bothers as im getting a new case and water cooling soon, so im gunnabe ripping it all apart anyway
ninuhadida    0
can you explain in detail how much fans/hdds/cd-drives you want/have ? i can't get a clear picture of what exactly what you want.
maybe i can help you :)
domoMKIV    0
as far as the bottom of the 830 being ventilated, im not sure. it doesnt have all the room like the stacker STC-T01 though, so you'd be blocking PCI slots with the radiator placed on the bottom.
as far as putting a radiator in the front with 5 drives, well lets see with some measurements.
Stacker STC-T01 - 20.75" tall
Black Ice Pro II - 10.9" tall
this leaves you with 5 bays left (since you have the usb/power on the top as the 6th)
mwenke    0
Cool ok, i was thinknig about it.
Now idealy i would like 5 drive bays (2x CD, Faan Contoller, Light Contoler and floppy) but i know thats not gunna happen. so i went and first of eliminated the floppy because i also have usb floppy drives from my laptops, so that will be ok. And then i can also dump my Light Controller. So the radiator is here: http://www.dangerdenstore.com/product.p ... =72&page=1 and uses 2 120mm fans.
From pictures i have gathered that the 810 has 11 open slots, and the 830 has 9.So if your able to fit 3 fans in.. 9/3 so thats 1 fan per 3 slots, so if i wanted to have the radiator i would have to have 3 drives max.I would probz be ok with the 810, but the 830 is soo cool XD. Some one that actully has the case, can you please confirm that you could fix that in the 810. (Btw there is a video of a guy installing that radiator into the 810, so it will fit, but im just intrested how many drives i can fit)
Another thing i otested, does the door on the 830 have holes or somethng.. caz wouldnt that stop the air flow...
domoMKIV    0
the 810 and STC-T01 have the same dimensions so it will fit in the front just the same.
i took the measurements on my own T01.
Fireheart    0
My studies of the 830 seem to indicate that the best place for your double radiator might be on the Side fan bracket.
How about horizontally, in the top two slots? That should avoid complications with the PCI cards.
Guest Mindless Moron
the spacing is incorrect on the side panel, if you can fit it inside jerry rig it to the back.
