Digital Paradox
Hyper 48(KHC-L91-U1)
Guest dogin
Guest dogin
Looking forward to your review Bigbadbns. Will it run on manual fan speed set vs heat sensing from mobo? Currently Gigabyte does not have a fix for the heat sensor on the mobo I am using and it shows extremely low temp. readings. I have to monitior the heat with an external sensor and adjust the fan speed accordingly. This may be a long term solution as Gigabyte has not made any progress with their last two attempts????
