Mark Johnson
Need help with argb fan SF360R and Asus Aura.
I purchased the SF360R ARGB fan as it is a single fan, and not three separate fans with three power connectors and three RGB connectors, so it simplifies wiring.  I am glad someone has finally made one.  I have been complaining for well over a decade for this simple solution to many different manufacturers.  I'm very glad CM has built one.
Anyway, I can't just plug in the ARGB connector of the SF360R as it has a blocked RGB pin connector.  The Asus has an extension cable, but it is full 4-pin connector.
Since it said it was compatible, I thought it was plug-n-play.  Apparently not.  Maybe I missed something?
Or do I just need an adapter from CM to Aura?  Where would I find it?
Thanks for any help.
-=Mark=-
EDIT:
Forgot to mention my motherboard is an:
Asus ROG Strix Z390-F Gaming
Edited by Mark Johnson
Missing info
Nothing?  This seems a straight forward question with an easy solution.  But apparently it is impossible?
I sure hate to return my product for a more straightforward fan solution.  At least my case has about 4-inches of room behind the motherboard to house multiple fan/rgb wires if I have to.
