Montz
ARGB Controller to 4pin header motherboard
Montz    0
Posted (edited)
i bought MasterLiquid ML240P Mirage ARGB Liquid Cooler.. as i finalize the setup, i noticed that my motherboard MSI B450 Tomahawk Max doesn't have 3pin 5v header.. will ML240P still customize its rgb using MSI mystic light sync software? im planning to attach the 4pin 12v wire from the argb controller to 4pin header of motherboard, because they said that the only way to use motherboard app is the controller should be directly attached to motherboard, but i need assurance that it will work and will not cause malfunction or damage to parts.. thanks
Edited by Montz
