-_JonA_-
Should it cool better?
Guest Mindless Moron
building your own setup or getting a kit sounds like a significantly better option, plus it'd be quieter.
merovingian    0
I agree, but will have less features and will be more difficult to install. If you want details, you can PM me.
A danger den gpu water block cost as much as the hole aquagate setup. Just put a 120mm rad on your rear 120mm fan . The pump will do great. You can get an Aquagate for $119 at newagg.
a danger den gpu block is $44 i dunno where you've been shopping. $60 for the decent brass one
-_JonA_-    0
what if I replace the 80mm fan with a 120mm fan (+fan-adapter)
and take out the radiator then... (just like a carburator !?)
but I think I only will cool my P4 3.00Ghz CPU and ATI 9800Pro(128mb)... that must work...!?
should it help if I attach my CPU and VGA in parallel?
I've heard once serial doesn't matter 'cause the watterflow is fretty fast...
frozencpu Danger Den NV-68 (Nvidia 6800 series) 1/2" ID Water Block Price: $124.95 Do we really have to start this crap again!?
Ya, but he said (a couple of posts up) that he as a 9800pro. They start at $44.95 on the DD site.
Create an account
Register a new account
Sign in
Sign In Now
