Andrew
aqua trident
RaptorFury    0
hmmm couldnt you change out to 1/4 inch barbs on the rest of the wawa components ? or switch out to 3/8 barbs on the blocks ? from the looks of the pics i seen and few reviews i read the Cm blocks seem to work just as well on a High FLow wawa set up ..
Andrew    0
hmmm. i guess i can switch the barbs on the trident, seems like it would fit. i was thinking of using 3/8 id tubes because im guessing 1/4 would be too small on a bigger pump. im thinking of using the Swiftech MCP655 or the similar polarflow pump. i guess ill just try it and see what temps i get first, thanks for all the help everyone.
