arpqstr
does MASTERFAN ARGB AND PWM HUB compatible with CM rgb software ?
arpqstr    0
I need to buy 1 argb hub to control 4 argb devices, but there is only MASTERFAN ARGB AND PWM HUB (attached in uploaded images) that is available in my area. so i wanted a clarification whether this device is compatible with cm rgb software or not. thank you.
DianaC    0
That is just a hub, not a controller.  All devices attached will follow a single lighting effect.  If you want zone control, you need a controller.
