Liam Wilcox    0
My PC has been making ticking noises recently and I'm 90% sure it is the AIO. It only makes the noise when CPU temp goes above ~62C as that's when CPU fan 1 goes from 0 rpm to around 700 rpm. Once it cools down, CPU fan 1 goes back to 0 rpm and the noise stops. The AIO is plugged in as fan 1.
Link to noise - https://imgur.com/gallery/Sn20LvE
Is the AIO making th noise and if so how do I fix it? Thanks.
Cenevit    5
What's your motherboard?
The pump fan header must operate at full speed.
You may need to disable fan control on the pump header in your motherboard’s BIOS.
