DjBodkin
Cooler Master ML240L RGB / Making strange noise
DjBodkin    0
Just bought my first liquid cooler for a resonable price. Started with idle CPU Temps of about 35 Deg. After a couple of weeks of use - gaming etc, I now have a strange noise and Idle temps are up to about 50 Deg. Is this noise normal and temps shown for the pocessor I have. I'm concerned that the pump might be failing or air lock. CPU Fan is set to full speed constant / heat compount has been applied as instructed by youtube turorial videos. Any advice would be great
Cenevit    4
Posted (edited)
Is the pump running at full speed?
Did the gaming temperatures raise up?
Lay the case down flat and let see if the pump comes quiet.
Edited by Cenevit
