Andrew
RGB 2.0 fix for Coolermaster ml360r
Andrew    0
When hooking up your device you can either use the controller or not doesn't matter MAKE SURE you have a Argb cable hooked to the controller or connect Direct as I did last night.. then go to your RGB 2.0 program and click the motherboard option as if you were to change colors. select your Dled option and you should see a button that says calibration [review screenshot below to see what it should look like]. Click it follow the directions Easy as Pie.
