Axel Lazuardi
MasterLiquid ML240L RGB Dripping/Bubbling Sound
Hello! I'm a new user of CoolerMaster MasterLiquid ML240L RGB for like, 2 months.
What I noticed for these 2 months is, I almost heard bubbling/dripping sounds on every PC startup. But I checked, there is no leak or anything. The bubbling/dripping sound only comes up during the pc startup, and then gone. Is there something serious happening here? Do I have to reinstall the whole thing or is it normal?
Thank you!
Cenevit    4
Posted (edited)
The pump is designed to run at full 12V.
You may need to disable fan control on the pump header in your motherboard’s BIOS.
Edited by Cenevit
