DuckyDanielz
Deepcool mattrex cf 120 fans?
Hello, first off i would like to say that there is nothing wrong with the fans im just quite confused. I purchased the deepcool mattrex 70 that came with an included set of 3 cf 120 fans. I have plugged them into my motherobard and use an onboard pc button to access and change rgb. I noticed there is little rgb to chose from and am wondering as to how i can plug this into an rgb header so that they can be controlled from software. it didnt not come with a controller or hub.
