Michel Karam
Replacing top fan 20030 A20030-07CB-3MN-F1
Hello,
I have the top fan 20030 A20030-07CB-3MN-F1 in my H922 since 2011 but now it's making loud noises sometimes so I will have to replace it.
My son would like to have an RGB fan instead so I am wondering if I can install this one as a top fan: MASTERFAN MF200R RGB
https://www.coolermaster.com/catalog/coolers/case-fan/masterfan-mf200r-rgb/
My motherboard is the ASUS P8P67 Pro.
If it's not compatible, any equivalent RGB top fan?
My fan is similar to this one:
Thanks
Cenevit    5
Posted (edited)
The RGB fan has two cables, one for fan connector and one for RGB connector.
Old motherboard doesn't have the RGB connector so that fan will work without the RGB lights unless you use a controller.
Edited by Cenevit
Posted (edited)
So I was trying to find this model to replace my top fan. I am in Canada, and I would like to order it online.
https://www.cmstore.eu/spare-parts/200mm-fan-700-rpm/
On Amazon.ca I saw this one but not sure if it's the original as the Cooler Master logo is hidden in the picture:
https://www.amazon.ca/Cooler-Master-R4-MFJR-07FK-R1-MegaFlow-200/dp/B008G3OLRQ/ref=sr_1_3?keywords=cooler%2Bmaster%2Btop%2Bfan%2B200&qid=1587906027&s=electronics&sr=1-3&th=1
Also your online store is not working it seems and I suppose it ships from the US?
Thanks
Edited by Michel Karam
