kekstime
Top Water Cooling in MasterCase MC500
kekstime    0
Hello,
I just wanted to ask if it would be possible to build in a Corsair Hydro Series H100i RGB Platinum (240 mm Fans) in a Cooler Master MasterCase MC500 Case at the Top. I would use the Cooler Master MasterCase Series Cooling Bracket and the CoolerMaster MasterCase 5 Series Top Cover Kit too. Is it possible or are there problems  that I overlook?
Thanks in advance for your answers.
kekstime
