ShanaSakai
Will the Cooler Master MasterBox Pro 5 RGB fit this motherboard?
ShanaSakai    0
Hi everyone! I've bought a dual CPU motherboard that is 30cm by 30.48 cm (11.8 inch by 12 inch) it is this motherboard here (hopefully links to Aliexpress is allowed): https://www.aliexpress.com/item/4000619561176.html?spm=a2g0o.cart.0.0.7c103c00OuO49o&mp=1
I am wondering if the  Cooler Master MasterBox Pro 5 RGB will fit this motherboard? From a first glance, it looks like it, but I would like to double check before I make the purchase, thanks!
https://www.newegg.ca/black-cooler-master-masterbox-pro-5-rgb-atx-mid-tower/p/N82E16811119330?Item=9SIA9H570Z7943
