ztbahbaz
Elite 110 front panel usb issues
ztbahbaz    0
I recently purchased an Elite 110 case from cooler master, and I really enjoy having the small form factor and the case is totally fine other than the front usb connectors. For some reason, they refuse to cooperate at all, I assumed this was possibly a driver issue so I went ahead and finished the build, installed windows, and installed all necessary drivers to no avail. Windows detects a constant disconnect/reconnect cycle when anything is plugged into the 2 front usb connectors and I’ve tried numerous documented software solutions with no success. I really don’t want to have to return the case and get a new one because I would have to disassemble the entire build, is there anyway that I could replace the front usb cables/pcb without replacing the whole case?
