Jan
Will Noctua NH-D15 fit inside Masterbox TD500 Mesh?
Jan    0
Hey guys, I'm wondering if Noctua NH-D15 chromax.black CPU cooler will fit into Masterbox TD500 Mesh case?
The NH-D15 height is at 165mm and the case CPU cooler clearance is also at 165mm, does this mean it's still going to fit or it won't?
Thanks.
Spacemanc0    0
Thanks.
According to PC Part Picker there appears to be no compatibility issues, however since I do not know the other specs of your planned build, and the numbers provided make it seem like it would be an extremely tight fit, it might be wise to consider a smaller CPU cooler, I believe a great alternative would be the ARCTIC Freezer 34 DUO since you seem to be after a push pull config, it comes in a variety of colors and has a height of 157mm, and plenty of clearance to access your ram slots, there is also a single fan option that will let you add a second fan, or if you just want to use different fans altogether, hope this helps!
