EricRonin
MasterBox Q500L and Arctic Liquid Freezer 240mm
EricRonin    0
Hey, so i have the MasterBox Q500L case, which i am enjoying. I wanted to test out the Arctic Liquid Freezer II 240 cooler, but i wanna make sure it actually will fit. I know the Q500L supports a 240mm rad on the top, but what is the max height of a rad+fans can it take without it conflicting with other things? The rad and fans are like, 38mm wide. I have an asrock x570 phantom gaming 4 motherboard installed if that helps. Just wanna make sure it'll clear well.
Thank you~
