Ryan
Best CPU air cooler for Q300L case?
Ryan    0
So I have a CM Q300L case and my Ryzen 5 3600 is reaching 89-90 degrees while benchmarking and gaming. The maximum height for a CPU air cooler that will fit in the case is 157mm. I had a Hyper 212 Evo in my old build and had great results with it. But those are 159mm in height so it won't work with this case.
So i'm just wondering if anybody can recommend an air cooler that will work with this case and bring down the CPU temperature substantially.
Thank you in advance!
