Azureblood2
HAF XB EVO Fan configuration
Azureblood2    0
I am building a new PC with the HAF XB EVO case using the Corsair H115i RGB Platinum and I am trying to figure out the best fan configuration to optimize cooling for
Ryzen 3900X
G.Skill Trident Neo 3600Mhz @ 14-15-15-35
Asus Crosshair Hero VIII X570
Gigabyte Gaming OC 5700XT
I plan on using this to have an additional intake from the left side of the case pointed directly at the GPU, but I am unsure of how this will affect the overall airflow in the case with the radiator fan right behind it.
For fans I have
  2x Corsiar H115i stock fans (97 CFM @ 3.0 static pressure)
  3x Noctua NF-P14s (78.7 CFM @ 1.91 static pressure)
  3x Corsair LL120 (43.25 CFM @ 1.61 static pressure)
  1x Noctua NF-A20 (86.5 CFM @ 1.08 static Pressure)
  3x Noctua NF-12 Industrial PPC 2000 (107.5 CFM @ 4.18 static pressure)
My first thought was:
Intake (244 CFM):
  Front: 194 CFM @ 3.0 static pressure (2x Corsair H115i stock fans pushing) >  27mm radiator  > 157.4 CFM @ 1.91 static pressure (2x Noctua NFP14s pulling)
  Side: 86.6 CFM @ 1.61 static pressure (2x Corsair LL120)
Exhaust (129.8 CFM):
  Top: 86.5 CFM @ 1.08 static pressure (Noctua NF-A20)
  Rear: 43.3 CFM @ 1.61 static pressure (LL120)  NOTE: I prefer this could be replaced with a 78.7 CFM @ 1.91 static pressure (Noctua NF-P14s)
My other thought was to move Noctua NF-P14s from the radiator to side intake (replacing the LL120s there)
Intake (351.4 CFM):
  Front: 194 CFM @ 3.0 static pressure (2x Corsair H115i stock fans pushing) >  27mm radiator  > pulling)
  Side: 157.4 CFM @ 1.91 static pressure (2x Noctua NFP14s)
  Top: 86.5 CFM @ 1.08 static pressure (Noctual NF-A20)
Edited by Azureblood2
fixing link
