Neotrl
MWE Bronze 550 noise of unknown origin
Neotrl    0
PRODUCT NAME
MWE Bronze 550
MODEL
MPX-5501-ACAAB
PROBLEM:
I bought this power source in the mercado libre, when I installed it on my armed PC, the source worked without problems, but after a week a strange sound began to sound as if something collided with the fan but there was no cable, I don't know the origin of what the sound can cause.
The sound begins to sound when I turn on the PC and for a period of 1 hour the sound is remarkable, then the sound begins to calm down.
The PC works normally but the sound is caused by the source, I do not know if it is due to low temperature since we are in December and where I live we are at 18 ° C.
evidence:
https://drive.google.com/open?id=13XFpiFt6vXw_SdYpuHTI7rkha13d39bF (sound no virus its a sound of the powersupply format .m4a)
More information on the energy source:
https://www.coolermaster.com/catalog/power-supplies/mwe-series/mwe-bronze-550/#Specifications
note: i use the traductor google XD
Edited by Neotrl
