HollyC15
Standoff placement for motherboard
HollyC15    0
I have an ASRock Fatal1ty x470 motherboard and a Cooler Master HAF 912 casing. I find that getting the screw holes for the motherboard and the standoffs, when placed in the casing, to line up properly, to be a bit of a frustrating challenge. I laid the motherboard down on the side of the casing, and used a sharpie to mark where on the casing, the screw holes fit, and well, they weren't close enough to the standoff holes for my liking. If anyone can give any advice on this, and suggestions for standoff placement so I can properly install the motherboard, it would be appreciated.
