Tiwill0v2
Coolermaster RGB Controller Amperage?
Tiwill0v2    0
Hey, so i'm going to (try to) make it quick:
Basicly, i've hide a couples of LED Strips(bought 10m of 12v 5050 RGB LED Strip that you can cut and i've put them all over my pc, didn't use the full 10m), i might have like 100+ Total LED(can't show them all on picture but here's a somes.
46D73488-B1AA-4AC8-B328-6EFDD5A7EA8F.thumb.jpeg.f75b0e3d220d02309053342e60d995fe.jpeg8B0D77F5-DFAD-4A28-A746-ED65EB3D96B4.thumb.jpeg.62c7f52fd17cd7860550af865a00f1a6.jpeg8BAEC2A7-C105-4B22-B030-24F1B46702CE.thumb.jpeg.b2d82a4c19e615236430d148e5017bef.jpeg
So i know it will draw a lot of power, so i taught: i could seperate them in "Zone" and use a controller to set them up via software. so i bought the Cooler master RGB Controller, the one with 4 output made for 12v led. and i wonder, What's the Amp on Those output? i can't find anywhere, i just want to know how Much LED i can put on each lines and if i will need to use my LED Plug on my motherboard(if the controller doesn't output enough power)
P.S. For the Curious, my case is the Corsair Conquer(picture over pf when it had working led setup), with a i7 7700k, Asus Z270 Prime A, EVGA 980 ti Hybrid and 32GB of RAM :p
Extra Pictures
FAD076C6-303C-411D-A7DA-CE57FE8E9442.thumb.jpeg.4584d1a26046204cbde6f358d197ee72.jpegA5F64AD4-F4BA-4C3B-8063-52A4C14C279A.thumb.jpeg.d7a52e1fc86f8c1621db64bd26c365c1.jpeg330797D3-1846-48AE-A8A3-D2ACAF7193C7.thumb.jpeg.cdf3b12d0aeed68d1037f72665a0d780.jpegC34BC24B-F2B8-45BD-967E-B7943B3B7500.thumb.jpeg.540127d626e4dc45376c594a2992126c.jpeg
