BahnShaps
Temps!!
BahnShaps    0
 Hi there,
I've recently upgraded my case and cooler. Case: Fractal Design Meshify S2
Cooler: CoolerMaster Masterliquid 240
Currently my temps are all over the place on my stock Ryzen 1700x, Mobo: MSI X370 Gaming Pro
It may be down to the connectors, as I've utilised the fan controller hub which you get with the case.
Connect the controller to the CPU fan header (one of the two PWM headers) and then connected the Pump, and two 120mm fans, to the three PWM connectors on the fan hub.
Could anyone help out on why this could be happening?
