cmthebest
CM Force 500 FOR-500-KKN1 side fans
cmthebest    0
Hello, i have a CM force 500
https://www.coolermaster.com/catalog/cases/mid-tower/cm-force-500
Anyone can help me understand how can i mount the two side fans at the right? I can't get how to do it with the provided screws, as putting them requires to set first the HDDs, and can't be adjusted to the panel.
I'm not planning to use it with a double cooling radiator.
Pick this one as i need to use it with 10 disks for a business, 8x3,5 + 2x5,25 with adapter, so the side fans will be really useful to cool the drives, besides installing also the front fans.
Thanks
PS: Is there any other CM case that can hold more than 10 ten drives?
Edited by cmthebest
cmthebest    0
Thanks
Hello! Anyone can help me with this? Thanks
