Empire
Power cable! Straight out cable connection! Needs to be flat!!
Empire    0
Why do you never see cable that's just straight and flat!
I'm putting my PC together into a new case, it has slide brackets (one in front of case where it display, and two in the back) that ssd drives only screws in on one side of the bracket.
The cable from power supply to the SSD isn't flat! Rather than like Here and how the SSD is mounted it's fully against the case back and there is no room or space to plug the cable in :(
I'm after a cable that will do the job but the connection to the SSD is flat! other then as shown in the image above but the wire comes fully out as in straight so that it goes towards out rather then inwards.
EDIT, I'm after THIS   My Item is RSC00-AFBAG1
Edited by Empire
