Zerohmaru
7 ARGB fans into one controller, can it be possible?
Zerohmaru    0
Hello everyone
I am planning to mount a PC with CM RGB, as I have been looking on internet I can't mount 2 CM controllers so the solution should be splitters. So, I make this topic to make sure my idea can work. There are 3 front fans (MasterBox MB530P)
2 front fans splitted = 1 connector for Controller
The connector explained above splitted to the third front fan = 1+1 connector, total 2
Split those 2 splitted connectors making it a total of 1 connector to the controller
2 CPU fans splitted = 1 connector for controller, total 2
2 top fans splitted = 1 connector for controller, total 3
Rear fan, making it a total of 4.
Can it work? I assume the splitted fans will work equally
Thank you
