Dac Khoa Nguyen
A-RGB fan setup arrangement with the A-RGB controller
Hi all,
So I have plan for the following fan in my system with an Aorus X470 Gaming 7 motherboard
  • 2x MasterFan MF120ARGB 3 in one (6 fans in total)
  • 1x MasterFan MF140 ARGB
  • 1x MasterFan MF140 RGB
The 140mm fan will be the standalone and plug straight into the mobo. That aside I am struggling to figure out the arrangement for the remaining 7 fans. I am considering the two options below:
Option 1: Using the small ARGB hub included in MF ARGB kit:
The drawback of this is that it can only support up to 6 fans so the MF140 ARGB will have to be wired directly to the motherboard. I cannot use two controller as the Masterplus software does not support 2 hub at once
Option 2: Using the bigger ARGB hub:
I contact Cooler Master Rep and they said this will be released towards the end of the year as a standalone unit
With this I can wired all my fans to one hub and control it from the MasterPLus software. The drawback is that I have to wait till some indefinite time in the future
I have some questions as below:
  • Which option should I go for?
  • What cable is required to connect the controller to the motherboard through the micro usb header connection and where to buy it? I was searching for that everywhere and have yet to find an answer.
  • Can I plug all 7 fans daisy chain to one small argb hub?
  • what happen when I plug an RGB fan to an ARGB hub?
Posted (edited)
Here is the cable
https://www.ebay.com/itm/20-inch-Micro-USB-Male-to-Dupont-5Pin-Female-Header-Motherboard-Cable-Cord-Line/272784673184?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
The ARGB and RGB hadders are not compatible and you´ll damage your fans if use a wrong led header !
The RGB has 4 pin (+12VDC/R/G/B) and the A-RGB has  3 PIN (GND/Data/+5VDC)
You can use in parallel (split cable) , but get though by the current supported by the controller !  At this way the parallel ones will run  like a single one , splitting the data info and power.
Sandro
Edited by Sandro Pacheco
