Omar
H500M Right Side Panel
Omar    0
Hi there i ordered my H500M last 3 october (Thursday) and i only completely unboxed it just today and checked it and smthing caught me offguard , the Right side panel (the one where u look at ur PC inside part NOT the back of the motherboard) is a bit loose compared to the left side panel is this a defect or that normal ?
Brendan    0
Definitely isn't normal for me. I have found that the screw/latch on the top is not even across the two panels though. Its much harder for me to remove the right side panel than the left.
If its very noticeable and bothers you I would suggest an RMA if you still can.
