Dito 0 Posted October 5 I'm nearly done transplanting a PC into a Masterbox Pro 5 RGB. I already had a CM RGB controller unit, so I wired everything up. When I boot the machine, the case fans are a nice, bright, solid blue. I can use the "RGB Control Software" application to monkey around and change colors, patterns - and brightness. However, if I try to do the same with MasterPlus (to link color schemes to different games), the fans drop to about 25% of their original brightness. There's no brightness control. Does anyone know what's going on? And how I can fix it? Thanks. Quote Share this post Link to post Share on other sites
