TMcPants
N200 front usb/audio cables
TMcPants    0
does anyone know if the N200 case front audio/usb 2.0 wires are replaceable and if so where to buy them? i have a N200 i was given to build a pc for a cousin
 windows is installed and case is fine except for the fact there are no wires to connect the front audio/usb2.0 with the motherboard
 it only has the power/hdd/reset which all work fine and it also has the usb 3.0 on the front which also works but there are no other wires? can anyone help me understand
 im 99% sure the cables have been taken out lost or misplaced so i need to replace but cannot find anything
 thanks for reading
