Wolf Moonstar
Help to improve cooling - MC500P
Currently I am running the 3x 140mm stock fans as intake with a single 120mm exhaust fan.  I was thinking of getting a set of the MF140R Airflow fans, but at the same time wonder if there would be a better solution.  Personally I would love fans that can inter-connect so I only have 1 header to go from the fans to my MB.  The only 140mm set I have found to offer this are the InWin Crown ARGB fans.
Anyway, the major reason behind this is my temps spike high while gaming...my ASRock RX 590 hitting 75C and Ryzen 5 2600X hitting 60C within minutes.  I believe the lack of airflow (exhaust wise) could be the culprit.  Any suggestions are greatly appreciated.
