ROBI
Riser Cable problem
ROBI    0
In C700M my riser cable wont post picture i tried it on another computer and In bios i set on gen3 but without success. I have: GA X570 Master, AMD 3900x and 1080ti...any instructions or just RMA?
thx
Deniz Roth    2
U tried your gpu directly? Else just rma but this cable is the worst riser cable i have ever seen. It cause lot of latency issues. I bought another one its working great. This one is cheap
ROBI    0
hi yes I tried directly and work...
pat34us    0
I am having the same issue, what cable are you using instead?
Aasimon    0
Your MB may not be getting enough power.
Check that you have connected all the PSU connections to MB at the top.
