PugFaceDown
MASTERFAN MF120R ARGB x6 Installation.
PugFaceDown    0
First time i'm going to build a pc, and i am twisting my brain on this.
So i am planning on getting the Cooler Master MB530P
This case includes 3 fans, each fan has one fan header, and rgb header.
The case includes the rgb controller (Small)
Now i need to connect 6 fans
My motherboard has 6 fan header connectors, so fan headers isn't my issue, but the rgb headers are, Is it possible to use two small rgb controllers? and if not, then what am i supposed to do, i will have two 1to3 argb splitters, and i am really confused on how i'm supposed to connect all 6 rgb headers from the fans, or do i need to buy the bigger controller?
Also if you guys could include a picture on how to connect all 6 fans with either, the small controller or the big controller, that would be most usefull!
Since i have a really hard time understanding this process.
So all in all, Instructions on how to connect 6 Cooler Master MASTERFAN MF120R ARGB fans.
My Motherboard is the Aorus Z390 Pro Wifi.
Please try to give the best instruction properly, since i am going to build my pc very soon, and i have to make sure i do it properly.
