Zachari 0 Posted September 9 Hi, I just built a new rig with these parts: PcPartPickerBuild When I connect the CoolerMaster Water Cooler ML120L RGB to the RGB pins on my motherboard the color lights up but is dim and will not change color. If I connect the RGB for the fan/watercooler directly to the PSU using one of the modular cables and the RGB controller provided in the package then the PC will not boot at all. Interestingly, If I connect the RGB for the fan/watercooler directly to the PSU AFTER the computer is already booted and running, then the RGB is bright and will cycle between blue and white. It will not display any other colors besides blue and white. Please provide Guidance on what to do. Thanks Quote Share this post Link to post Share on other sites
