Shafarevich
HAF XB Evo Removal of X-Dock
Shafarevich    0
I would like to fit a long PSU (200mm long) into HAF XB Evo. The spec of the case says it supports PSU of length up to 180mm. I am considering removing the X-Dock that sits in front of the PSU to allow more space for the PSU. However, it appears that removing the X-Dock would leave a hole at the front. Is there anything you can buy to cover up the hole, say a filter?
