ales iac    0
I recently bought a MasterLiquid ML240R RGB and it all installed perfectly. I have no problems with the cooling or noises. I installed the controller and it worked for like 2 min the turned off. I didn't short it or anything. When i plug it back in after disconnecting it, it turns off then goes to one light mode then completely shuts off again. Idk what to do weather I claim it on warranty or if i can get a replacement part. Any help would be amazing.
Thanks
